Oil pressure gauge light
Discussion in 'GMC Truck Forum' started by Troy, Nov 19, 2017.
  1. Troy
    Troy New Member
    Nov 19, 2017
    So I decided this would be an easy enough task with little working knowledge on vehicles. turns out it wasnt as easy as i thought. in order to get to the oil pressure sending unit you have to remove the distributor from its place to get to it. i struggled trying to get the distributor off so i sort of gave up on the idea and tried to reclip and button it back up to how it was before.
    I tried to start my truck, however it wont start now and i have a check engine light on now.
    12,741
    7,894
    what are you working on?
    is it seated properly in the block?..
    .if it was raised high enough it may now be 1 tooth off
    MikeG, gmctrucks and kbrown11 like this.
  3. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,223
    2,144
    Alburquerque
    Did you have to unplug any electrical connectors? Maybe the coil connector isn't plugged or seated all the way.
  4. Troy
    Troy New Member
    Nov 19, 2017
    I am trying to replace my oil pressure sending unit because my check guage light came on and the oil pressure guage was going back and forth between 0 and 30. i youtubed a video of how to replace the sending unit and i got everything taken off to get to it minus my distributor. im having issues trying to get that off. i bought a distributor wrench to get in the tight space but im not having any luck trying to get the bolt off. so i put everything back together so i could take my truck to a buddies house but now the check engine light is on and it wont turn over (it wants to) but wont. i double checked that all of the plugs were still in place and the clips on the distributor were re-attached. i put my air filter back together and buttoned it all back up. i started with a truck that would start before i tried to fix the sending unit, now im without a truck that starts
  5. Troy
    Troy New Member
    Nov 19, 2017
    i did get the two connectors back on a "snapped" back into the distributor
    kbrown11 likes this.
  6. gmctrucks
    9,057
    4,796
    Check if your on top dead center
    MikeG and kbrown11 like this.
  7. Troy
    Troy New Member
    Nov 19, 2017
    I was never able to get the distributor pulled out.
  8. dirtrider73068
    6,881
    4,393
    The check light will come on with just the key on or when you first start it after the ecm does it check the liht goes off it has to start and run for this to happen otherwise the light is on when the key is on or when you are trying to start it.
    Make sure its getting spark and fuel. Make double sure everything is connected where its suppose to be, some connectors may not go where they need to and still plug in. IIRC on the distrib the ignition module has two connections and iirc one for the pick up coil that is inside the distrib so should be 3 connections that what gets the ecm signal and sends signal to fire the coil. Make sure nothing else got unplugged.
    To get the bolt out on mine I used a one end wrench adn found a old one adn think cut it in have to reach, don't give much in leverage. That bolt does not have to be real tight just good and snug enough to keep the distrib from moving when you gas on it. Keep checking there is something not plugged in or plugged into the wrong spot.
  9. leolkfrm
    12,741
    7,894
    what are you working on meant, year make model engine
  10. gmctrucks
    9,057
    4,796
    I know but if it’s one tooth off your going to have to set it back on timing as the video let’s you know and I’m thinking you have just a regular 5.7 V/8 but we don’t know...
