OMG...My door chime won't SHUT UP!!
Discussion in 'Chevy Truck Forum' started by celinaman060, Sep 1, 2008.
  1. celinaman060
    celinaman060 Member
    Jun 27, 2008
    I just replaced the interior driver's side door handle because it came off in my hand. I put a new one in and now my door chime won't turn off :)flamingmad:) unless I turn off the ignition and remove the key. Now, I didn't reassemble the entire door yet because I don't want to have to take it apart again. Please help. Thanks.
  2. brad4eva
    brad4eva Senior Member
    Apr 10, 2008
    463
    none atm
    Tennessee
    model? yr?
  3. junior3382
    junior3382 Senior Member
    3,171
    89
    inside the door lock mechanism is the sensor to tell the ECU the door is open. When you reinstalled the door handle assembly, you may have not connected that sensor properly. I have a similar issue in my Mazda, but simply pulled the fuse. Double check the old vs the new and make sure it went it properly.
  4. celinaman060
    celinaman060 Member
    Jun 27, 2008
    1995 Silverado 1500. Also, now I notice that my interior lights will not turn off even when the dor is shut.
  5. rdhack
    rdhack Senior Member
    Jun 29, 2008
    184
    Science Education
    kentucky
    Shoot It! :)
  6. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    levittown pa
    pehaps you messed up the pin that tell the bell to stop dinging when you shut the door. just a thought
  7. mudseeker
    581
    is the door interior back on? is the little "button" on the door still there where the pin on the dash touches?
  8. celinaman060
    celinaman060 Member
    Jun 27, 2008
    I'm sorry guys, I'm such an idiot. The kill switch for the door chime is on the left hand side of the dash. If you don't put the whole door panel back on it never comes into contact with the switch. Sorry for wasting your time. Thanks anyway.
  9. heavychevy85
    heavychevy85 Senior Member
    May 30, 2008
    317
    lawn care and landscaping
    Muncy, PA
    it sometimes comes down to the dumbest things for somthing to happen right wich i'm sure we all have done i know i have just thaught i throw that out there
  10. junior3382
    3,171
    89
    after muds post, that was going to be my thoughts... I forgot that some of those fullsizers had it set up like that. Glad to see you got it fixed though.
