outside edge of front tires wearing?
Discussion in 'GMC Truck Forum' started by partsman, Jul 5, 2012.
  1. partsman
    partsman Full Member
    Jul 5, 2008
    339
    91
    Poco BC
    so this 1996 K2500 long box 4X4 I have had for about three or so years is wearing the outside of the front tires, had it into Kal-Tire here and in a mechanical check at that time they said all was good and so was the alignment, but that it was caused by not rotating the tires, I don't recall normally rotating tires, and any two wheel drive vehicle I have had never showed this type of wear, so is this what happens on a 4X4 truck and is normal and that one can prevent it by rotating tires?
    And if so, how often should one rotate tires?
    Thanks.
  2. batty1214
    batty1214 Full Member
    Nov 2, 2008
    2,276
    508
    Mine Mechanic(tire guy)
    Vernal Utah
    Depends on how fast they are wearing..... most people will so it every other oil change.... I have a few truck I service that I rotate them once a month.... but, im betting you have something wrong in the front end.
  3. partsman
    Jul 5, 2008
    339
    91
    Poco BC
    Thanks for the quick reply, I am at work, but checked my previous posts and see I got the truck in feb 2009, and I have never rotated the tires, so the wear is probably normal, but I might run out at break time and take a picture, and it will show how it looks after all this time.
    I also notice with a four by four that when I turn sharp I feel like the tires slip or something as if the way they are made with the front axles they have more play when turning, if that makes sense.
    It is like the tire and hub and all must not be as solid as my old ford solid axle two wheel drives.
    Usually tires wearing on outside alignment is toed out to much..or camber is out.
    Camber is the way a tire/wheel leans ..to wear on outside ..top of tire is leaning out .
    Can put a short level on tire ..see the lean. Tires that are not rotated and keep pressure check on those..and alignment is good will wear even.
    These shops if trucks are 10 years and older ..do not want to mess withem.
    Plus most have no ideal how to align. Take it to a another shop .
    Be nosy ..ask them about being toed out ..maybe camber ...ask them if caster wold do it.
    If they say caster might do it then they have no ideal. Caster is when a vehicle pulls left or right.
    I use to align vehicles ...probably get a better alignment with a tape measure and level ..than the machines.
  5. leolkfrm
    12,436
    7,515
    yes 4x4 need the tires rotated more so than 2wd....as you turn they have a differant path to follow compared to 2wd and will wear the edge....a good 4 wheel alignment here cost me about $90 plus parts
  6. Boudin
    602
    The wear pattern on the outside is most likely caused by the reasons mentioned above. You mentioned that since you haven't rotated them since owning it and that being the cause of the wear is not correct. You should have the tires wearing evenly no matter if you rotate them or not. Given that you have this wear pattern, rotating the tires will just do the same to the other tires. Fix the cause if you want to get the most life from your tires.
  7. partsman
    Jul 5, 2008
    339
    91
    Poco BC
    Okay, here are pictures, on of the right and one of the left tire.
    You need a alignment...either toed in too much or camber is off . Tires do not wear like this even if not rotated or low on air.
  9. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    levittown pa
    it looks like you have your torsion bars jacked up past their limit. if so then the tires will be aligned when going straight but around a turn they will carve different paths or you have some bad upper contol arm mounts that are moving around under the load of turning.
