Oxygen Sensor replacement--HELP!
Discussion in 'Chevy Truck Forum' started by jessevargas, Jul 18, 2008.
  1. jessevargas
    jessevargas Full Member
    Sep 10, 2007
    Oxygen Sensor location on a 94 Silverado
    I want to change the oxygen sensor on my 94 Silverado, 2x4, 5.7L. I looked where the ALLDATA diagram shows where it is located but it's not there. Does anyone know where it's located. Am I'm losing it or what?:confused: To me this is showing it is on the driver side, on the exhaust manifold.
    Thanks in advance for any help!:D
  2. 03chevy
    03chevy Senior Member
    Dec 28, 2006
    1,244
    50
    factory warehouseman
    jax,fl
    look further down off the manafold about 12" down and i can not remember if they have them with the cats too.
  3. rdhack
    rdhack Senior Member
    Jun 29, 2008
    184
    Science Education
    kentucky
    Look on the passenger side just before the Cat converter. You probably have to lay on your back looking up. It is probably a 3wire.
    mudseeker likes this.
  4. jessevargas
    Sep 10, 2007
    OK thanks,I'll have a look today. The Sensor that I bought has one wire, though.:eek: Hmmmmmmmmm......... I'll let you know.
  5. jessevargas
    Sep 10, 2007
    That's where it was and it is a 3 wire. Looks like it going to be kind of tough reaching in and connecting the wires. Any suggestions? Thanks for your help!:D
  6. rdhack
    Jun 29, 2008
    184
    Science Education
    kentucky
    I warmed my truck up for about 5 minutes. Used an adjustable wrench with a cheater pipe to initially break it loose, then used a O2 socket for the rest of the job. get your tools ready before warming up the truck.
  7. jessevargas
    Sep 10, 2007
    O2 Sensor--Help
    OK, so I've got my new sensor, my tools ready, the truck is jacked up but I've no idea how I'll be able to connect the sensor. The connector is back where I cannot (I think) reach. The wire coming from the truck doesn't seem long enough. Any suggestions?
    Thanks in advance,
    Jess
  8. junior3382
    junior3382 Senior Member
    3,171
    89
    there should be a plug right in the back of the O2 sensor.... unless it is one of the older ones, and even then, it should reach unless it has been altered from stock. But if that is the case, how are you at cutting and splicing? LOL.
  9. mudseeker
    8,754
    580
    there is a plug and yes, they are a pain to reach sometimes.
    one end of the plug is most likely connected to the body or frame with one of those annoying little plastic tabs.
    as a last resort, do as junior said and snip, snip
  10. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    levittown pa
    How long is the new wire comming from the sensor. That is where the old connector should be unless its the wrong part. It happens quite often i would double check your part numbers first. Perhaps remove the old one and take it to the parts store with you
