P0719 code need help
Discussion in 'GMC Truck Forum' started by Randy z71, Oct 30, 2017.
  1. Randy z71
    Randy z71 Member
    Oct 30, 2017
    I need help. My truck is throwing a code p0719 changed brake switch. Checked fuses wires that i can think of an still nothing need to get it smogged an can't till this is fixed. Cruise control doesn't work. Driving on freeway press brake an gas no rpm difference. Please help!!!!!!
    6,881
    4,393
  3. Randy z71
    Randy z71 Member
    Oct 30, 2017
  4. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,022
    2,370
    Fort Wayne, IN
    Did you use an AC Delco switch? After market switched are hit or miss and don't last long.
  5. Randy z71
    Randy z71 Member
    Oct 30, 2017
    Yes I used an a.c Delco. An my brake lights an everything are working correctly. An i just bought it changed it an problem is still there.
  6. dirtrider73068
    6,881
    4,393
    This may take time but check all the wireing, connections make sure they are tight and not loose check grounds they can cause funny issues. If circut is low its not getting full power and a bad loose ground could cause this as well as a short. Will do have a wireing diagram thread somewhere, may look there see if your year of truck is posted and follow wires.
  7. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,022
    2,370
    Fort Wayne, IN
    Here's a thought, check your 3rd barke light. Cruise doesn't work on some trucks if it's blown.
  8. Randy z71
    Randy z71 Member
    Oct 30, 2017
    Do you happen to know what wires I should check to see if it's loose. Sorry to be a pain just not to big on electrical an it seems to be that type of problem. An also yes 3rd brake light is out I will go to Wal-Mart an get the bulb for that now an update you when I'm done. Thanks you.
  9. MikeG
    2,800
    2,070
    Richland, Wa
    :idea: Maybe check to see if the 3rd Brake Light has it's own fuse ...........?
  10. Randy z71
    Randy z71 Member
    Oct 30, 2017
    So third brake light fixed an problem is still there!!! Such a head ache.
