Passenger door will not open from inside
Discussion in 'Chevy Truck Forum' started by Johnny Driver, Aug 3, 2009.
  1. Johnny Driver
    Johnny Driver Member
    Aug 3, 2009
    1997 Chevy C-1500 Sierra 3door extra cab 2wheel drive. The passenger door will not open from the inside. Started intermittantly then one day would not open. Inside handle works fine and the door will lock automatically and manually. Can only open from outside handle...any ideas?:confused:
  2. Wyley87
    Wyley87 Senior Member
    Jul 20, 2009
    664
    linkage from inside door handle is probably loose or has came off, have you ever replace the door handle on that side?
  3. Johnny Driver
    Aug 3, 2009
    No, I have not replaced the door handle and from what it looks like it is the original one.
  4. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    my bet is it is the inside door handle. they have a habit of bending, breaking etc... real easy to pull off and check out to make sure. remove trim (pops off) and there is only 1 or 2 bolts (can't remember) and door handle comes out.
  5. Wyley87
    Jul 20, 2009
    664
    ok well theres only one way to check to see if its the linkage and you gotta remove the door panel to do it. know how?
  6. Johnny Driver
    Aug 3, 2009
    Don't really know how but I am going to find out! Guess it is time to go out into the 100+ Texas heat and get er' done. Any advice will be greatly
    appreciated.
  7. 64shortbed
    64shortbed Senior Member
    May 12, 2009
    198
    sound like to me the handle broke we do them all the time at work.
    to remove the door panel you should have a trim remover tool but... if not a good flathead scewdriver will work. you well also need a philips screwdriver.
    door panel removal (be carefull and take your time dont force it)
    1. remover the 2 screws from the arm rest
    2. remove trim around door handle (snaps on use a small flat srewdriver work you way around it between handle and trim should be 4 tabs that hold it on)
    3. remove triangle piece (it covers the nuts for the out side mirror) on the top of the door panel use flat screwdriver or (trim tool) it has one tree clip
    4. remove window switch panel (should pop up at the back of it if i remember right you my skip this step but it is easyer to unplug it this way then to do it after you remove the door panel)
    5. unplug switchs(good idea to have window rolled down first)
    6. start at bottom of the door panel and slide flat screwdiver (trim tool) in between door and panel
    7. start poping the tree clips out (usually push out taward the door with screwdriver (trim tool)
    8. after you work your way across the bottom work your way up the sides
    9. once there all out you can remove the door panel by lifting up a little so it will come out of the window seal area.
    10. unplug the door light and you have removed the door panel
    im sure thats all the steps but just be carefull and donot force it i may have forgoten a screw but i cant remember
    if you break some tree clips replace them they are cheep and you can buy them at any parts store you can also buy the handle from ant good parts store in the color you need if not the standard is grey
    now the handle
    1. door panel removed drill out the 1 rivit and slide the handle forward.
    2. undo linkages and you have removed the handle
    its wise the re revit the handle but i have used hex head screws to hold them in place to because i dont have a big rivit gun
  8. Wyley87
    Jul 20, 2009
    664
    ok well since you've never done this be for heed my working DON"T FORCE IT!!! there remove the door triangle first with a little tug it should just pop off. also the bezel around the handle must be removed carefully with a flat head screw driver. also there are 2 screws where the "U" handle is. after all that carefully pry the door panel off the door becareful not to brake the little plastic clip things. if you get frusterated go inside where the ac is have a glass of water cool down, collect your thoughts and try again.
    good luck
  9. Wyley87
    Jul 20, 2009
    664
    **** beat me to it :(
  10. 64shortbed
    May 12, 2009
    198
    sorry lol :rofl:
