Pulling trucks out there?
Discussion in 'Other Trucks' started by Bad88, Dec 10, 2014.
  1. Bad88
    Bad88 Full Member
    Dec 8, 2014
    2,085
    4,045
    New York
    I've got a 88 Chevy Silverado that I am in the process of turning into a street legal pulling truck. I will eventually be powering it with a 364 CI DART SBC (680 HP and 540 l/ft of torque). I'm looking at the front & rear diff's thinking about what gear ratio I want to run. Tires are 33". Tranny is currently a 700R4 with a 241 transfer. I will be putting in a TH400 and a 205 at some point. Front axle is a 8.25 IFS. I will run that until I swap it out for a Dana 60 King pin and the rear will be a Corp 8 bolt lug.
    Would be interested in what others are doing.
  2. BurbanMan
    BurbanMan Full Member
    Jul 22, 2014
    1,230
    990
    Stove tech @ true value
    Cortez, CO
    I'll tune in to this.
    YEAR.........
  4. rocketron
    rocketron Senior Member
    Aug 3, 2013
    332
    493
    tree surgeon and Landscaper
    Phila.Pa
    I would put that powerplant in a nova or vega and kick butt at the dragstrip. If I want to pull something I'll borrow one of Lonesomes tractors. Lol
  5. BurbanMan
    Jul 22, 2014
    1,230
    990
    Cortez, CO
    lol wheres your sense of adventure rocket?
  6. MrMarty51
    Here is My pulling, picking, packing and hauling truck.
    4:10 rear, 4:09 fronts. Fronts is geared higher to allow for turning/maneuvering in mud~N~Snow.
  7. Bad88
    Bad88 Full Member
    Dec 8, 2014
    2,085
    4,045
    New York
    Update: Not much to report. Rolled the bed off to get to the frame to media blast and undercoat. Am replacing all rear brake lines; replacing fuel lines; replacing fuel tank; replacing fuel sender/pump; new rear gears & carrier; new rear brakes ([shoes, drums, hardware]soup to nuts); new u-joints; new axle bearings, and new carrier bearing. I will replace the master cylinder since (upon inspection) is has a puddle of crud in the bottom.
    I rebuilt & reinstalled the front differential (IFS). Putting in a different motor (small block) just to see what else needs done (no idea if the tranny or transfer even work).
    I have not even started looking into the front brakes but I know they are not impressive looking at all. I will inspect everything closely but if I know myself at all, I will put new calipers, pads, and all new hardware on regardless.
    I found a small crack in the frame just in front of the right side motor mount. Will weld that up once I finish media basting that section of the truck.
    Am wondering what kind of electrical issues I will run into once I get everything back on and twist the key for the 1st time. This truck has not run in many years.
