Rearend Gear size? 96 c1500
Discussion in 'GMC Truck Forum' started by Wyley87, Jan 21, 2010.
  1. Wyley87
    Wyley87 Senior Member
    Jul 20, 2009
    664
    Arlington, Tx
    ok i was looking at a post on a different forum where a guy was pulling a trailer and was wanting to change the gears out in the rear end. Anyway i have always wondered what size the gears were in my rear end. How do i find out?
    1996 GMC C1500 with 305 and 4L60-E tranny.
  2. 75K30
    Are you asking for the diameter of the ring gear or the ratio of the gear set?
  3. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    forklifts and equip tech
    Tupelo Ms.
    id say you have a 308 ratio and an 81/2 ring gear. not 100% sure though.
  4. 1500cheyenne96
    1500cheyenne96 Senior Member
    Sep 1, 2009
    858
    14
    construction laborer/ hand on family farm
    MIchigan
    well if your asking for the ratio it's more than likely a 3.42 as most of the trucks for 88-98 that was the standard gear ratio for both 2wd and 4wd but some of the 2wd's 1/2 tons had 3.73's as well
  5. davbell22602
    winchester, va
    I have 90 C2500 2WD 3/4 ton 8 lug and I have the 3.73 ratio.
  6. gpmorgan
    Nov 21, 2009
    2,687
    288
    Tupelo Ms.
    i was going off of what my truck had. 81/2 ring 308 ratio.92 chevy 350 700r4. replaced them with 410 ratio and 8 1/2 ring gear.
  7. 1500cheyenne96
    Sep 1, 2009
    858
    14
    MIchigan
    Really it had a 3.08 stock? wow i've never heard of that for those trucks i know it was pretty common on the 73-87 models but i didn't know that any 88-98's had a 3.08
  8. gpmorgan
    Nov 21, 2009
    2,687
    288
    Tupelo Ms.
    yes 308 22mpg highway. but now with engine change and ratio change it gets 10 mpg:no::(
  9. 1500cheyenne96
    Sep 1, 2009
    858
    14
    MIchigan
    yeah but at least it'll get up and go there quicker:)
  10. cajun cruiser
    cajun cruiser Senior Member
    Jan 25, 2009
    57
    aviation composites
    mesquite,tx
    just jack up the rear end and mark your tires and driveshaft, turn both tires at same speed one rotation while someone else counts the rotations of the drive shaft and thats how to get the ratio, or if you have the codes in the glove box you can look that up
