reverse lights not working?
Discussion in 'Chevy Truck Forum' started by bigshot846, Mar 24, 2010.
  1. bigshot846
    bigshot846 New Member
    Mar 24, 2010
    my reverse lights aren't coming on when i put my truck in reverse, all the others work, what is the problem? my friend said something about a switch on the side of the transmission?
    its a 2000 silverado ls with the 4.3
  2. wild bill
    wild bill Senior Member
    Jul 16, 2008
    327
    davenport iowa 52806
    lights
    first check the fuse and then the bulbs ,then the backup light switch for adjustment or just failure . check were you loose power and go from there.
    crabtruck likes this.
  3. crabtruck
    #3 crabtruck, Mar 24, 2010
    Welcome to the forum bigshot846.
    Start by checking the 25A B/U LP fuse.
    Where the switch is depends on which trans you have.
    M/T should be with trans,
    A/T is part of the park/nuetral position switch.
    You also want to check the 15A VEH B/U fuse.
    If the fuse is blown and blows again when replaced,
    remove the TRLR B/U fuse to simplify troubleshooting.
    Theoretically that smaller 10A fuse should have blown first
    if it was a problem with trailer wires, but doesn't always.
    Wires at trailer connector can cause problems even if no trailer.
    Good luck and let us know what happens.
  4. MsCeCe
    MsCeCe Full Member
    Apr 29, 2009
    44
    check your tail light connector plate, I found this to be my problem when my backup/ signal didnt work. Sometimes they short out, check with your local parts store, their inexpensive.
