Rocker stud
Discussion in 'Chevy Truck Forum' started by brad4eva, Feb 11, 2009.
  1. brad4eva
    brad4eva Senior Member
    Apr 10, 2008
    463
    none atm
    Tennessee
    anyone know any good way to install screw in rocker studs with the heads still on the motor? I need to know what size and etc is best to use. does anyone have a video of this process?
  2. silverhairdeere
    silverhairdeere Senior Member
    Feb 15, 2008
    1,831
    33
    disabled
    land between the lakes tn
    i would Say no as there is no room around head to do it , also i would think you would want a machine shop to tap them straight , after all there is a lot of tension on the stud . just my own opinion for what it's worth . (nothing):rofl:
    shd
    12,431
    7,514
    I agree with SHD, major machine work should be done in a controlled environment with someone who is skilled in the process
    Did you try the oversize stud and hot relash??
  4. wild bill
    wild bill Senior Member
    Jul 16, 2008
    327
    davenport iowa 52806
    studs
    no ! the head's have to be removed !or you will fill the engine with metal shaving's and chip's . why do want them ,are the stock press in's puling ?:confused: you can just put screw inn stud's only or do stud's with guide plate's . i always did them off the engine .i was in a machine shop they can be labor intensive .
    bradrhale likes this.
  5. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    Heads need to be removed...
  6. brad4eva
    Apr 10, 2008
    463
    none atm
    Tennessee
    well your saying no to screw ins .. wtf am i gonna do? they keep pullin out press ins
  7. brad4eva
    Apr 10, 2008
    463
    none atm
    Tennessee
    do i need to keep air on the valves? if so how
  8. silverhairdeere
    Feb 15, 2008
    1,831
    33
    disabled
    they make a tool that screws into the spark plug hole , use a air hose to kept the valves closed , are you running a big cam ? never herd of it on a stock engine .shd
  9. brad4eva
    Apr 10, 2008
    463
    none atm
    Tennessee
    yep, running a big cam, anyways its pissing me off fixing to yank both heads and just have them screw ins put in im pissed
  10. wild bill
    Jul 16, 2008
    327
    #10 wild bill, Feb 12, 2009
    studs
    how many are pulling ?all the same one's ? they do make over size press in stud's .but the hole has to be reamed .if it's only 1 stud that does it mr. gasket used to make screw in stud's that had a shoulder on them .what engine is it ? if you are going to try it ,and only one or two are doing it ,use grease on ,and around the tap to catch the chip's .clean it good with brake clean on a cloth and clean out the threads and use red loctite on the thread's .http://www.jegs.com/p/Mr.+Gasket/747114/10002/-1
