Service Engine Soon light
Discussion in 'GMC Truck Forum' started by ralphmorgan, Jan 7, 2006.
  1. ralphmorgan
    ralphmorgan Member
    Oct 18, 2004
    :( My service engine soon light came on on my 2002 GMC 292 engine. The light stayed constant under 30 MPH and blinked above 30 MPH. I could feel a miss. I found that while deer hunting a rat had made himself at home on the engine (probably because it was warm) and had chewed two wires that go to a sensor(I think) on the block just above the coil. I spliced the wires and now the miss is gone but the light stays on. How can I get the light to go off? Is there a trick to it or do I have to take it to the dealer? Thanks:)
  2. shopratles
    shopratles Senior Member
    Dec 26, 2005
    172
    Mech. Engineer
    Here in Texas where I live you could take it to some auto parts stores and have them shoot the codes (make sure you have solved all your problems). When they do that they can shut the light off (temporarily - if you still have a problem it will come back on) and it won't cost you anything. I would think though that the light should correct itself - maybe depending on the code though.
    Good luck.
  3. ralphmorgan
    ralphmorgan Member
    Oct 18, 2004
    Thanks Shopratles. I live in Texas (Rockport) and have heard that AutoZone among others can help. I just had the problem Friday and spliced the wires today and haven't driven the truck, just started it and saw that the light stayed on. I was wondering if a do-it-yourself trick might turn the light off.
  4. shopratles
    Dec 26, 2005
    172
    Mech. Engineer
    That was the store I was thinking of. I don't know of a do-it-yourself trick but will keep my eyes open. Oh and I live in Mansfield (SE of Ft. Worth).
  5. 72'CaminoKid
    72'CaminoKid Senior Member
    Jun 19, 2005
    2,757
    29
    there is a way to clear all the codes urself..... turn key on, but dont crank it, then disconnect battery for about 3-5 minutes, turn key off, re-connect battery
  6. 72'CaminoKid
    Jun 19, 2005
    2,757
    29
    i believe this is how you do it, we did this on my dad's, and it cleared the codes. he has a 96' silverado. u may want to wait for gmtech to let verify this method. i'd hate for it to mess up ur comp. if this aint the right way
  7. chevyguy
    chevyguy Senior Member
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    96 and 2000 have different electronics, Drop by an auto zone and have then read and clear the code. If it comes back you will now where to start looking
  8. ralphmorgan
    ralphmorgan Member
    Oct 18, 2004
    Well thanks guys for all the input. But it is a moot point now. The light went off. I drove about 40 miles, went in Academy, came out and cranked the truck. No light!!!!!!! I guess when I fixed the problem, the computer took a while to recognize the fix and then turned the light off. shopratles you were right, it fixed itself.
  9. shopratles
    Dec 26, 2005
    172
    Mech. Engineer
    My '96 Z28 used to do that. Light would come on last 2-3 days, then shut itself off. Crazy car. Glad I could help. :D
  10. gmtech
    gmtech Senior Member
    Dec 3, 2005
    348
    Gm auto technician
    farmville Va
    Thats the way the computor does it. It needs 2 and sometimes 3 consecutive drive cycles where it tests and passes for whatever code there is then it can turn off the light but the data and code still stays in history in the computor for 100 drive cycles for most codes. And a drive cycle does not mean just starting and driving it 2 - 3 times it has to cool below a certain point be driven and warm beyond a certain point and then be turned off to be considered a drive cycle. As far a clearing a code without a scan tool the capacitors of the computor need to be completely
    powered down in order for it to loose its information and touching the 2 cables together has been a common way of accomplishing this task. It has even been recomended by our tech assistance for some certain codes that don't seem to want to be cleared by the use of a scan tool.
