slight surging problem in 89 chevy 305 tbi
Discussion in 'Chevy Truck Forum' started by Diesel_Fan, Oct 16, 2008.
  1. Diesel_Fan
    Diesel_Fan Senior Member
    Jun 24, 2007
    104
    West Texas
    my truck will be idling and then it will surge a little bit then idle way down and the surge back up. any clues to this problem, i just changed plugs, air filter and all, i havent changed the wires cap or rotor yet but im curious what this could be, when driving it seems to be right on the money just when im idling in gear or neutral even it does this. thanks alot.
  2. stumpuller454
    Dec 26, 2007
    2,206
    65
    Idle AIR CONTROL will be located on throtle body, near butterflies, try cleaning it first, but it may be a inexpensive part anyways...:)
  3. barbermike34
    barbermike34 Senior Member
    Oct 5, 2008
    73
    barber, part time reale estate, pt firefighter
    west kentucky
    I had the same problem on my 89 Chevy 4x4 and stumppuller is right on the money. I cleaned mine with carb cleaner and it worked for a month or two then i had to buy a new one.
  4. leolkfrm
    12,433
    7,514
    also check the egr for closing all the way
  5. FaselZ71
    FaselZ71 Senior Member
    Oct 4, 2008
    1,177
    Unemployment!!!
    Northern Michigan
    Something I've wondered is what is the point of the EGR I mean it just goes from the air cleaner to the exhaust heatshield!
  6. stumpuller454
    Dec 26, 2007
    2,206
    65
    its to help emissions reduction....its it no way help economy, in fact it probly lessens fuel economy....
  7. FaselZ71
    Oct 4, 2008
    1,177
    Unemployment!!!
    Northern Michigan
    Ok I was just think everybody say check the egr and what not. I don't even have an EGR anymore I'm just running open element
  8. stumpuller454
    Dec 26, 2007
    2,206
    65
    yeah it can cause probs, if its stuck open all the time usually the engine dislikes it untill it warms up....
  9. jimbo543
    jimbo543 Senior Member
    Sep 5, 2007
    208
    14
    GM/MOPAR certified tech
    MN
    fasel 71 hope this helps.
    EGR = Exhaust Gas Recurculation, egr valve is mounted on the intake that introduces exhaust into the combustion chamber to lesson nox emmisions.
    EFE = Early Fuel Evaporation, a valve on the air cleaner snorkle that directs warm air via tube/hose connected to ehaust manifold when a switch applies vacum to valve.
  10. jimbo543
    Sep 5, 2007
    208
    14
    MN
    had an 88 w/same deal, removed tbi, cleaned up, removed iac and cleaned (was pretty clean), by the throttle linkage on the front side there is either a small soft plug or small hard plug to adjust throttle, the hard one has be cut out, soft one pries out, turn idle screw IN 1/2 turn and truck should be ok. screw sets minimum air rate.
