steering column
Discussion in 'Chevy Truck Forum' started by davbell22602, Nov 12, 2009.
  1. davbell22602
    winchester, va
    90 c2500 heavy duty regular cab with tilt steering wheel
    I'm trying fix my steering column. Its very loose like someone was using steering wheel to pull themselves into the truck. I can pull on the steering wheel and part of steering column will try to come out. Its secure under the hood but loose inside the cab. The bolts are tight where the metal plate is at holding the column up. Does anyone have pointers or pictures on taking sections the of the steering colmun apart?
  2. tc123
    tc123 Active Member
    Nov 10, 2009
    25
    Military
    Middleburg FL
    Mine's not as bad but makes terrible noises; I would like to see a breakdown, as well.
  3. cburcham73
    cburcham73 Senior Member
    Aug 22, 2008
    305
    electrician
    williamsburg virginia
    do you have tilt wheel?if so there are 3 bolts that loosen up over time.you have to pull the wheel and you may need a gm special tool to remove the pivot pins.
  4. Crmzendrgone
    Crmzendrgone Senior Member
    Apr 6, 2009
    3,218
    Mechanic. Mr. MOM
    Arizona
    #4 Crmzendrgone, Nov 12, 2009
    This is what I could find but it looks like the later models.
    Here is another one I know it says corvettes but I am sure they were not that different from trucks.
    The third one is the one you want
  5. davbell22602
    winchester, va
    My local gm parts department said they don't sell tools but here's a gm part #J21854-01. I can the get pivot pin remover/puller from sears, snapon, and mactools. Nobody in the winchester,va area has the tool local. I have buy it over the internet.
  6. gmctrucks
    8,262
    3,845
    I don't think this will help but on my 1976 Firebird it had some nylon bushings that were worn I think even a bearing it's been a long time ago. I would remove the steering wheel and look for worn parts I think your steering wheels has a steel o-ring just push down on the wheel and you can pry it off like I wrote it has been a long time that I worked on a Burb I had as well.
