steering wheel loose, too much play
Discussion in 'GMC Truck Forum' started by pearsont74, Sep 27, 2010.
  1. pearsont74
    pearsont74 Senior Member
    Oct 27, 2009
    173
    St Pete, Fla
    I have gotten used to it but my steering wheel seems to be too loose...too much play in it, any thoughts as to if this can easily be tightened up some. i know my truck is pretty off on its alignment but i cant afford to get that fixed at this time since i just spent alot on the engine.
  2. bradrhale
    tighten the bolts that hold the column up?? or are you refering to a different kind of slop??
    12,433
    7,514
    you just said what the trouble is, an alignment is cheaper than tires, and they wil tell you what else it needs
  4. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    i'd check the rag joint, tie rod ends, idle arm and all steering components. it could be a combination of things. if its just in the column it could be the tilt or steer shaft bushings.
  5. scavanger
    scavanger Full Member
    May 15, 2007
    1,711
    1,265
    Pitman arm on the steering gear gets real loose in the joint to the linkage.
    scav
