still have harsh shifting problem on my 93
Discussion in 'Chevy Truck Forum' started by 93bluesilverrad, Mar 31, 2013.
  1. 93bluesilverrad
    93bluesilverrad Full Member
    Dec 29, 2007
    410
    127
    93 1500, 5.7, 4L60E...harsh shifting from park to reverse and drive, sometimes on 1-2 shift, rest are ok. history: truck went into trans shop due to free reving rpm increase on mild acceleration onto freeway in I blieve 3rd gear...all solenoid replaced--three times, no joy. finally shop replaced ecm with OEM brand from autozone and that problem went away......now came the harsh shifting issues so all solenoids were changed, three different times, I saw valve body down twice and still no joy. I myself replaced a broke temp sensor on top of intake, broke vac line of some type that went to the MAP ( not sure when or how these were damaged) and finally the TPS which seemed to significantly help the harsh shifts EXCEPT for the park to reverse and drive and this is intermittent and most noticable when truck has been turned off and sits. example going thru fast food drive thru and turning off truck and putting into park for couple minutes or when starting after work or overnight. Help.....could the ecm be defective or is it one or all of solenoids or ?????????? thanks for advice.
    22,214
    12,851
    12,309
    7,414
    i would check the tps, number 26, seen it on my 90
  4. dirtrider73068
    dirtrider73068 Moderator
    6,254
    Need to check the grounds, make sure they have good clean tight contact, and check wires make sure none are rubbing or shorting out, but if that happens should get a check engine light if it shorts out a sensor.
  5. 93bluesilverrad
    Dec 29, 2007
    410
    127
    new tps, grounds cleaned and tight, no bad wires etc. so I am at loss
  6. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    forklifts and equip tech
    Tupelo Ms.
    Might need to check the servo. I'm not a trans man but I'm pretty sure it has something to do with shift pressures.
  7. 93bluesilverrad
    Dec 29, 2007
    410
    127
    all solenoids/servos changed before, 90% of time still get harsh shift from park into reverse or drive, quick but firm on other shifts except 40% or so the 1-2 shift is harsh.....still searching for some kind of solution as trans shop can't figure it out.:( I am afraid a hard part will brake and on top of that it is really annoying and ticks me off.
