Trivia Question: International 345 engine
Discussion in 'Off-Topic' started by davbell22602, Feb 25, 2010.
  1. davbell22602
    winchester, va
    #1 davbell22602, Feb 25, 2010
    Which cylinder do you use for timing a International 345 engine? Here's the firing order 1-8-4-3-6-5-7-2
  2. hotrodpc
    hotrodpc Full Member
    Jul 29, 2008
    7,277
    110
    Moore, OK
    Oh I bet I know this one. And I bet I figured out why too. To be more explanatory, When timing this engine using a timing light, which plug # would attatch the timing lead to?
  3. davbell22602
    winchester, va
    Does somebody have an answer besides the hotrod and I. Take a guess.
  4. 436'd skylark
    436'd skylark Senior Member
    1,143
    Mac Tool Distributor
    Pennsyltucky
    its either the number 4 or 8. can't remember which. when I get home I can tell you. its stamped into the valve cover..
  5. oneluckypops
    oneluckypops Senior Member
    Feb 9, 2010
    841
    21
    Central Missouri
    Number 8 6-8 deg.
  6. davbell22602
    winchester, va
    yep, #8 it is.
  7. davbell22602
    winchester, va
    Here's a picture of the engine firing order.
  8. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    I think I know why it was done that way, or at least an idea of why. Anyone else have any ideas? Pop? 436? Would sure seem strange to time on #2 of the firing order, but I am sure there was a reason. Dave shut up ;), you already know what my suggestion was and why, so you are disqualified your answering, unless you have a differant theory than mine.
  9. oneluckypops
    Feb 9, 2010
    841
    21
    Central Missouri
    I cant remember for sure For some reason I want to say its because of the direction the engine rotates.
  10. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    My guess was, because where #1 would have fallen was probably under the water pump, and a timing tab would not have been visible, and certainly not with a timimg light, so they jumped to the second plug wire in the firing order, to get the timing tab in a visual location. Whudda you think about that guess?
