truck blowing black smoke
Discussion in 'Dodge Truck Forum' started by Lucys truck, Jun 30, 2007.
  1. Lucys truck
    Lucys truck Member
    Jun 30, 2007
    Hey guys, my 2004 Dodge Ram 2500 with a hemi is blowing a heavy black smoke out the tail pipe and my check engine light just came on at 40000 miles. I am now only getting about 8mpg highway. Any idea what is wrong with my truck?
  2. 75K30
    Welcome to the site.
    Truck is running too fat. Might never get to "closed loop" and running full rich. Get a scanner to pull the code. Might go to local parts store, they will pull the code, and sell you a set of sensors. Easy to install, they will even have the O2 sensor socket. Sometimes the sensor goes bad because it does not ever get to temp. and it thinks it is still cold, so it goes full rich, heak any number of variables can cause this, but the first thing to do is check the code, it is there to tell you what is wrong.
  3. peterbilt
    peterbilt Senior Member
    May 29, 2007
    1,966
    highschool inmate, lol, work with my dad
    Florida
    is it a diesel? my dads blows black smoke at the exaust pipe every onc in a while.
  4. Lucys truck
    Lucys truck Member
    Jun 30, 2007
    Follow up to problem
    No, its not a diesel. I went to an auto parts store and they hooked it up to a handheld unit and gave me a print out that said it had 2 codes and the both said Fuel System Too Lean. I asked if it was too lean why am only getting about 8 mpg and it blows smoke. They had no clue how the 2 problems could be the same. I spoke with a tech nician at the dodge dealership and he said that if a sensor is malfunctioning which would make the system think its not getting enough fuel then forcing more fuel through the system. Which would create the black smoke and the bad fuel mileage I am experiencing. I have an appointment Thursday to have it looked at. Does this explaination seem valid?
  5. Ford4x4Chik27
    Ford4x4Chik27 Senior Member
    Sep 19, 2004
    1,725
    Full time mommy
    Sac-Town, Cali
    What were the codes??
  6. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    yeah. If it is a bad 02 sensor or dirty egr valve it'll cause it.
  7. scottie
    scottie Senior Member
    Jan 6, 2006
    644
    Mercedes Benz tech
    South Florida (Palm Beach), originally from south
    yeah, if the comp is reading that the mixture is too lean, but its not, it gonna dump as much fuel into the cylinders until it reads that it is at stiochiometery (a fancy word for perfect air/fuel ratio). most likely a old O2
  8. Lucys truck
    Lucys truck Member
    Jun 30, 2007
    Follow UP.
    the codes are P0171 and P2098
  9. peterbilt
    May 29, 2007
    1,966
    Florida
    well, i think you guys got it handeled.
  10. mudseeker
    8,754
    580
    the first one is telling you your system is running to lean, which you know already. i'm not able to find the second one, did you write it down right?
