Truck will not idle correctly
Discussion in 'Ford Truck Forum' started by KyJIM, Sep 7, 2011.
  1. KyJIM
    KyJIM Member
    Jun 28, 2011
    My 97 Ford F150 with a 4.6 litre will not idle in gear properly it idles just fine in park . I replaced both Ignition coils because they were the original Ford factory part ,Truck has almost 172,000 on it ..Just wonder if oxygen sensors would cause my problem. Plugs and wires seem to be ok . I was troubleshooting out of Haynes manual . Any thoughts out there . The truck also has a new Maf sensor .
    22,214
    12,851
    Are you getting service engine light? I would do a good tune up ... plugs &wires fuel filter ect. Probably running a little rough in park also.. when you put in gear put a little pressure on engine notice it more. If you have no service light will not be 02,s ect. Could try cleaning the maf.
  3. zombie1969
    zombie1969 Senior Member
    Jun 30, 2010
    1,016
    CT
    Clean the throttle body also.Get some carb clean a tooth brush a rag and go to town.Make sure you get around the blade real good.
  4. tjzz4
    tjzz4 Senior Member
    Oct 5, 2007
    459
    29
    Could be IAC
  5. KyJIM
    KyJIM Member
    Jun 28, 2011
    Ok thanks i will look into the things suggested .
  6. KyJIM
    KyJIM Member
    Jun 28, 2011
    Oh yea the check engine light was on but i took the negative battery cable off and reset it , it went out drove it hasnt came back on yet .
    22,214
    12,851
    Run truck till code comes back scan.. will lead you in right direction.
  8. KyJIM
    KyJIM Member
    Jun 28, 2011
    Ford F-150
    Its a plug wire issue cylinder 5 some moisture on the wire where i didnt drive it alot i assume .. The car parts place call for just Bosch spark plug . I am thinking autolites have to be just as good ..
  9. chevychase
    22,214
    12,851
    Auto lite better than bosch.
