trying to bleed clutch for days
Discussion in 'Chevy Truck Forum' started by chevy builder, Jan 22, 2006.
  1. chevy builder
    chevy builder New Member
    Jan 22, 2006
    I have been trying to bleed a 85 chevy clutch
    I have heard to not pump the pedal so I pushed it down held it opened the bleeder and closed it before It was raised. I have done this several times. Then I took off the slave cylinder and opened the bleeder and pushed the push rod in while holding in the rod I closed the bleeder I have done this process many times. I have a good feeling pedal but not enough to engage it. please help Im pulling my hair out and dont like to go to repair shops
    by the way its a new slave cylinder
  2. 72'CaminoKid
    72'CaminoKid Senior Member
    Jun 19, 2005
    2,757
    29
    try unbolting the master-cylinder and holding it where the hoses comming out are at the top..... this way the air is also at the top and will be forced through..... hope you understand what i'm saying, if not, i'll try and explain a little better
  3. gmtech
    gmtech Senior Member
    Dec 3, 2005
    348
    Gm auto technician
    farmville Va
    Im not sure if this works on the older clutches but it works on all the newer ones. Just fill up the resevoir and pump the heck out of the pedal for 30 seconds or so and walk away. Come back in 30 minutes and see how it is. This works on all the newer masters and reseviors never need to manualy bleed them. I hope it will work on the older ones and what have you got to loose.
  4. shavo
    shavo New Member
    Feb 5, 2006
    what have you replaced on it
  5. jchcomputers
    jchcomputers Member
    Jan 31, 2006
    I did the same thing.. i bled it for days... I bled it at the master cylinder and the slave... then i just closed all the bleaders and pumped the **** out of it and all of a sudden got good pedal
  6. 72'CaminoKid
    Jun 19, 2005
    2,757
    29
    still having troubles? or you get it bled?
  7. chevyguy
    chevyguy Senior Member
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    You had an air bubble in the valve sounds like. Glad to hear you got it.
  8. gmtech
    Dec 3, 2005
    348
    Gm auto technician
    farmville Va
    So I guess pumping the heck out of the older vehicles works. On the newer ones don't even need to open any bleeders just pump wait awhile top off fluid pump and presto clutch works. Glad you finaly got it
