Tube and tubless tires swaped on tube and tubeless rims
Discussion in 'Chevy Truck Forum' started by Down South, Apr 18, 2012.
  1. Down South
    Down South Senior Member
    Jan 25, 2012
    462
    21
    South MS
    I got a guy telling me you can swap them no problem, just run a tube on the tube rim.
    This is crazy right?
    DS
    You can put a tubeless valve in a tube rim put a tire on it . there is no difference in tires.
    They do not know what rim they are on. Is this what your asking mr. ds.
  3. Down South
    Jan 25, 2012
    462
    21
    South MS
    To start this off 30 years or so ago when tubeless became common, I was told by the biggest ( of 3) tire guy in town that you couldn't swap its all different.
    Now this involves tractors and specifically front end loaders. The old days you put old 7.00 6 ply truck tires on your tractor for cheap and loaders 7.50x16 (6 or 8) cause it was best ( wider heaver duty) all are tube type.
    I know tube type have 5 degree rim walls, thicker bead area and a slightly different shape than tubeless and usually a flap and tube..
    Tubeless have 15 degree rim walls, thinner bead area and more rounded beads.
    I got a great pic showing both from a pdf file on a word doc but cant figure how to get it so i can post.
    I talked to the #2 tire shop in a much bigger town and they say Maybe, they would have to look at what i got.
    I told them a tractor and still maybe they would have to see, couldn't tell me what they look for.
    Now most tractor rims are 4.5 wide, you can get 5.5" imagine putting a 235/85/16 tubeless ( normally 6-6.5 wide rim) on a 4.5 or 5.5 wide tube rim.
    The point is its hard to find the old tube truck tires in decent condition.
    DS
  4. leolkfrm
    12,433
    7,514
    as far as i can recollect the only diff was a hole to let the air out on tube loader rim(between the rim and tube)...smaller truck tires didn't need it as the air would come out around the valve stem
  5. leolkfrm
    12,433
    7,514
    i'm running 245-16 truck tires from my 2500 on my backhoe front with out any problems for 3yrs
