violent shakes
Discussion in 'Ford Truck Forum' started by Blade South, Mar 19, 2012.
  1. Blade South
    Blade South New Member
    Mar 19, 2012
    my 1978 ford f150 is having violent front end shakes when we hit the brakes, we replaced the calipers and master cylinders and it stopped it when applying the brakes, now it does it when i reach random speeds, ive been told to rotate my tires, replace tie rod ends, sway bar and to have it aligned, does anyone know of any other possibility, i want to get it fixed and get my baby back on the road
    Had a ole 78 done that ..was the drag link /what tie rods and other components connect to.
    Does it drink? maybe going into dt,s/detox Had too see my signature. Nut.
    :rofl::rofl: or :flamingmad: or:no: or :help: but that is funny think.
  5. leolkfrm
    12,741
    7,894
    i would have a good front end shop check it out and decide who is going to fix what....it would be worth the fee for you to only replace what you need to
  6. chuckchuck
    chuckchuck Full Member
    Feb 28, 2011
    HAVE YOU CHECKED THE TRACK BAR? THIS STABLIZES THE FRONT AXLE IN SIDE TO SIDE MOTION!
  7. 1978 F150
    1978 F150 New Member
    Dec 15, 2017
    Same problem here . New bushings in front end fixed my truck!!!!! Problem solved!!!!
  8. gmctrucks
    9,057
    4,796
    If no parts worn out make sure your wheels aren’t caked with mud on the inside of the wheels that would throw off the wheel balance and make sure you don’t have a bad tire.
