vortec head or double hump heads?
Discussion in 'Chevy Truck Forum' started by slims, Mar 1, 2010.
  1. 436'd skylark
    436'd skylark Senior Member
    1,143
    Mac Tool Distributor
    Pennsyltucky
    Digging up a square bore intake for vortec heads will be easy.
    Dave- whats this intake adapter you speak of?
  2. davbell22602
    winchester, va
    just a thought. don't know if they make one really.
  3. gmctrucks
    8,743
    4,400
    I say use the double hump heads and let me buy the Vortec heads from you. Have you done research on the double hump heads? Watch them be better than the Vortec heads.
  4. 436'd skylark
    1,143
    Pennsyltucky
    The vortec heads are far superior to the old double humps... no question there.
  5. gmctrucks
    8,743
    4,400
    You just messed up for me I wanted to buy the heads from him. LOL I agree if there better I would go with them as well plus they have holes for A/C brackets and so on.
  6. slims
    slims Senior Member
    Mar 1, 2010
    222
    tug captain
    gonzales La
    the truck isnt a street truck. it has 4.11 gears and a hefty 3 speed trans. im just runnin out of thing to do to it beside the vortec heads, nitrous or some kind of forced induction
  7. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    im running 461 double hump heads on my 355. no bolt holes. only had problem with alt but made my own brackets. the heads have had ports enlarged and im running a comp 294s solid lift with 525 lift. 410 rear gear with 700r4. i run this truck on the street with no problem. with block milling and 2 valve relief flat top pistons its putting out around 425 to 450 hp. a blast to drive.
  8. hotrodpc
    hotrodpc Full Member
    Jul 29, 2008
    7,279
    112
    Moore, OK
    Yep, the vortec is a much better head for flow. The differance is NOT only the bolt pattern. The intake ports are taller on the Vortec head, that is how they are able to move much more air and flow better. They also have accessory holes. :woot: There is no such adapter either. Camel Humpers are very old school these days.
  9. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
    #19 gpmorgan, Mar 2, 2010
    i agree they are old school but they make a whole lot of power with very little mods for larger camshafts. what adapter are you talking about?
  10. 436'd skylark
    1,143
    Pennsyltucky
    if ya don't know you shouldn't post WRONG info. people come here to learn, not get sent on a goose chase.
