Why would my truck stall then run then stall?
Discussion in 'Ford Truck Forum' started by Lonesome7.3, Dec 2, 2016.
  1. Lonesome7.3
    Lonesome7.3 Full Member
    Jul 21, 2008
    5,101
    994
    Columbus GA
    Since I am sitting on the side of the road waiting for a tow truck right now, I figured I would get some help diagnosing the problem. I have a 1988 F250 with a non-turbo IDI 7.3. I was at a salvage yard earlier driving up a steep hill and the truck died. It shows 3/4 of a tank. I sprayed some gasoline down the intake and the truck fired up. I drove to a gas station as I was pulling in it died again. I coasted to a gas pump sprayed a little bit of gas down the intake it fired up and ran again. I got to the intersection about to turn onto the Interstate and it died once again. Any ideas?
  2. Lonesome7.3
    Jul 21, 2008
    5,101
    994
    Columbus GA
    I forgot to mention, when I left the first salvage yard I went to another one. I parked the truck, shut it off, and walked around for a little while. I came back and the truck fired right up without a problem. After that is when I went to the gas station and it died there.
    7,920
    fuel filter, diesel or gas? if diesel fuel shut off switch
    MrMarty51 likes this.
  4. Lonesome7.3
    Jul 21, 2008
    5,101
    994
    Columbus GA
    Diesel
  5. leolkfrm
    7,920
    then fuel filter, and shut off solenoid, make sure there is only 1 filter, back in the 80s gm had one on the return line also
  6. Lonesome7.3
    Jul 21, 2008
    5,101
    994
    Columbus GA
    I did not think of the solenoid being a problem.
  7. dirtrider73068
    6,925
    4,442
    Could be sucking air from somewhere, could be loosing fuel, not much on diesel just guessing the basics here.
  8. MrMarty51
    The fuel shut off solenoids on any diesel would be the first suspect.
    I would start with that then go from there.
  9. Lonesome7.3
    Jul 21, 2008
    5,101
    994
    Columbus GA
    The biggest problem will be getting it across the state back to my shop.
