10 spline Np205 help
Discussion in '4x4 trucks / off road' started by Angryk20, Mar 26, 2018.
  1. Angryk20
    Angryk20 New Member
    Mar 26, 2018
    Plumber
    Az
    I have a 78 chevy k20 with a muncie sm465 and a divorced 10 spline np205 t case. Driving down freeway noticed something in the drivetrain trying to bind or lock up, slight and quick shudder. Well long story short, parked the truck in the garage and here it is two years later and finally pulled the t case. Front input bearing missing almost half the bearings. There not in the case and it was moving and driving when i parked it. All the gears look ok except the output shaft gear. Now im having trouble finding a 10 spline output shaft. Can find 32's all day long. Can i just put a 32 in it and get a different yoke? I heard the early 10 spline 205 used a 80mm bearing and the later ones used a 90mm and would the seal be a different size also
  2. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    510
    134
    detention officer
    bozeman mt
    they outdated the 10 spline kits early80s i cant remember the lasto one i saw. but i do know they make a retro fit kit for the 32 spline set similar to this qu50345 - Torque King 4x4
