1973-1987 (91) NL2 Dual fuel tank systems theory of operation
Discussion in 'Chevy Truck Forum' started by hatzie, Jan 16, 2018.
  1. hatzie
    hatzie Full Member
    Mar 17, 2014
    421
    739
    Northern New England
    There were three fuel valves used between 1973 & 1991.
    None of the systems are rocket science to repair once you understand what makes em tick.
    On all three systems...
    -The fuel is routed from one of the tanks to a common OUT port. Only one tank at a time is valved open to the output port.
    -If the truck is equipped with a fuel return line the common return port from the engine is switched from tank-to-tank as well.
    -On systems with a return line... The return line should be routed to the tank that fuel is being drawn from. If you mix up the return lines you can overfill the tank not being used. Hosing down the guy in the next lane with raw fuel may not garner a friendly reaction.
    -Both LH tank lines into the same side and both RH fuel lines into the opposite side.
    -the COMMON side of the valve To/From-The-Engine only has 1 or 2 lines. Feed and, if equipped, Return.
    NOTE: It's worth noting the 1981-1991 systems likely all have return lines. I haven't run into one without.
    **1973 & 1974 & some 1975
    Cable System... had a cable operated valve with a SPDT switch behind the dash knee panel that activated via the cable to run the fuel gauge. If you google it you'll find a thread on Chris's board about the valves with pictures of this setup. This is LONG obsolete. Folks replaced them with the 75/76-80 system when the parts ran out but there are a few survivors. NOTE: I'm not sure whether this system used the NL2 RPO or not... The 1975 wiring diagrams list the cable system and then NL2 in separate panes.
    **1975/76-1980
    Solenoid system... used a single wire solenoid valve with three or six ports.
    --The valves returned to a rest position as soon as power was removed. In 1980 GM added a retained power relay to keep the valve energized in the AUX position while cranking. <-- Click to see the post about this timer relay.
    --The AC Delco 467513 Six port valve or a similar function unit was used on trucks that came with return lines. These are not being produced by Delco or any other manufacturer. If you feel like spending big bucks search that part number they occasionally show up on evilbay.
    --Three port valves were for trucks without return lines.
    NOTE: Standard Motor Products sells a three port version FV1 but there are no six port solenoid valves available. Folks have used the 1981-1991 Pollack valves but generally they butcher the wiring.
    -Four wires run through the firewall.
    --Two tank sender wires.
    --One Dash Gauge feeder wire.
    --One Solenoid Valve power wire.
    -The dash switch is a five terminal DPDT (Double Pole Double Throw) ON-ON rocker switch.
    ----Each switch is called a pole and each switch position is called a throw...
    ------Double Pole means there are two switches actuated by one rocker.
    ------Double Throw means there are two different switch positions with a common input or output terminal.
    ------ON-ON means there are two ON positions with no centre OFF position.
    --The reason there are five and not six terminals is to key the switch to the connector such that it can only be plugged in one way. You can use a standard 6 terminal DPDT ON-ON rocker or toggle switch by clipping off one of the switch terminals to match the original switch.
    --On the three terminal side of the switch there's one wire direct to the dash gauge in the common position and the fuel level sender wires to the switched terminals. This selects which sender is routed to the dash gauge.
    --The two terminal side of the switch is still a double throw switch but it's missing one of the switch terminals to key the connector. This is so it can't be plugged in backwards. It also assures that the unwashed masses will buy switches from GM and not McMaster Carr or Grainger or... It has one power wire from the fuse panel, or a relay in 1980, on the centre common terminal and a green wire that routes power to the solenoid valve when the switch is set in the AUX position.
    This is a depiction of the internal switch action.
  2. hatzie
    hatzie Full Member
    Mar 17, 2014
    421
    739
    #2 hatzie, Jan 16, 2018
    **1981-1991
    Motorized Valve system... used a six port motorized valve made by Pollack. These are still being produced by Pollack on Jan 1st 2018.
    • The "universal" valves that claim they're three port usually have all three return line ports capped. You can use either just be sure to cap any unused ports to keep dirt out of the valve guts.
    • The later motorized valve remains in the last switched position unlike the earlier solenoid valves.
    • Pollack 42-159 Motorized valves are available with 65PSI limits for some, but not all, later EFI systems. The originals were rated for lower pressures.
    Electrical;
    • The Pollack valve uses five of six cavities in a Six position Weatherpack plug. A-E are used. F is plugged with a seal.
    • Internal to the valve are two diodes to prevent power being routed to the motor from D or E once the valve shuttle has reached the end of its' travel.
    • The motorized valve has a SPDT switch to control which sender feeds the gauge shortening the wiring considerably.
    • *The gauge/Sender wires are on positions A, B, & C of the valve.
    • **Senders from the tanks are on switched terminals A & C.
    • **The gauge output is on Terminal B. This wire runs to the molded sender wire connector on the RH frame rail. This allowed GM to just drop in the NL2 as a sub harness without having two main harnesses.
    Motorized tank switch details...
    • [​IMG]
    • The above switch depiction is a Polarity Reversing DPDT switch used to turn a DC motors forward or backward depending on position. GM used a proprietary switch but this exposes what the GM switch actually is doing.
    • Two of the switch contacts do not have terminals. These contacts are bridged back to the other switched terminals diagonally across the switch.
    • Output to the DC motor in the valve comes from the common terminals of the switch.
    • Power and Ground run to one switched terminal of each half of the switch.
    • When the switch is toggled to the opposite position the LH & RH MOTOR terminals of the switch reverse polarity. + becomes - and - becomes +. The valve motor then runs in the direction dictated by the polarity it's receiving on D & E til the stop on the valve shuttle cams the internal gauge and motor switches over to the switch leg with a diode that blocks the incoming current. The motor then stops til the dash switch is toggled back to the opposite position.
    • You can see below that... On the 1987 RV series TBI trucks the selected fuel pump receives Power on the wire from the switch so it will activate because it has power and the shared frame ground. The UN-Selected pump receives Ground on the wire from the switch thus shutting it down because it now has two ground wires and no power.
    The following two panes should be pretty decent visuals of what I was saying with the last two above bullets.
    NOTE: Stock 1981-1986 & Diesels don't have a 2 position Weatherpack disconnect at the sender with Fuel Pump Power (just a single sender wire from A or D on the valve), and obviously no in-tank fuel pumps, they are otherwise identical in function to the TBI setup.
    TBI TANK SWITCH SET TO RH
    TBI TANK SWITCH SET TO LH
    1981-1986 & 1981-1991 Diesel TANK SWITCH SET TO LH
    NOTE ON SWITCHES:
    • Usually, but not always, the switch is at fault for a non operational valve. The switch is cheap as in $10-$15. Change it if the wiring looks OK and the valve doesn't work.
    • 1981-1991 I ALWAYS REPLACE the motorized valve switch with the 1987-1991 RV series AC Delco D7809 or Standard DS-1807 1987-1991 R/V 10-30 "TBI" ON-ON switch. I never have been able to figure out why GM used a centre off switch on the early 80's trucks... The Pollack motorized fuel valve always had the over-travel protection diodes and switch built in.
    • For those of you that want a "Correct restoration" 1981-1986 GM used The AC Delco D7003 Momentary ON-OFF-ON switch that has "DEPRESS FULLY" emblazoned on the bezel. I NEVER USE THE D7003 SWITCH... IMHO it's a problem child because of the momentary action.
    1987-1991 RV series TBI Fuel Pump Relay for TBI tank switch and fuel pumps.
    Year specific information can be found in the 1987-1991 Emissions and Driveability service publications. You can find them in my manuals post.
    The TBI fuel pump relay can be found on the firewall between the transmission tunnel and the Heater/AC box.
    Fuel Pump relay without "Hot Fuel Handling Relay".
    Some 5.7L & all 7.4L Fuel Pump Relay and Hot Start Fuel Relay with Fuel Pump Test Terminal shown.
    Fuel Pump Relay Control
    • When the ignition switch is turned ON the Electronic Control Module (ECM) will energize the coil in the fuel pump relay. The ECM will energize the fuel pump relay coil as long as the engine is cranking or running and the ECM is receiving distributor reference pulses. If there are no reference pulses the ECM will cut power to the fuel pump relay coil within 2 seconds after ignition ON.
    • As a backup system to the fuel pump relay, the fuel pump can also be turned on by the oil pressure switch. The oil pressure switch is, normally, open and closes when oil pressure reaches about 28 kPa (4 psi). Fuel Pump Power through this switch is also cut if the engine stops running as the oil pressure will drop.
    • If the fuel pump relay fails, the oil pressure switch will run the fuel pump to allow you to drive to a safe location and repair the problem. However. You will experience extended cranking times because the fuel pump will not run at all til the starter builds oil pressure. This will shorten oil pressure switch and starter lifespans if the failed fuel pump relay is not diagnosed and corrected.
    • The pump will deliver fuel to the Throttle Body where the system pressure is controlled to about 9 to 13 psi. Excess fuel is returned to the fuel tank by the pressure regulator.
    • A Hot fuel module is used on all 7.4L and some 5.7L engines to correct a hot restart (vapor lock) during a high ambient temperature condition. It is designed to over-ride the ECM 2 second pump operation and will run the fuel pump for 20 seconds at initial ignition switch "ON”.
    • The dual tank switch harness connects switch power at the "Bulkhead Connector" in the below Fuel Pump Relay schematic.
    All years NL2 system NOTES:
    • Since the 1975/76-1991 NL2 dual tank systems used a sub-harness that plugs into the RH tank sender wire on the RH frame rail and power comes from the fuse panel under the dash or the TBI fuel pump power connection. It's fairly easy to retrofit and or update to a later model system.
    • You can swap a 1981 -1991 motorized Pollack valve sub harness into a 73-80 truck. You need the entire later model NL2 sub harness from the fuse panel/ground bar to the dash switch. Two wires run through the firewall to the valve and one wire from terminal B of the valve to the RH frame rail disconnect of the "production tank" sender wire.
    • BTW I've used the Delphi Packard 56 switch plug for a 73-80 system on a generic polarity reversing switch and rolled my own harness to convert a single tank truck to a dual tank truck. Much easier to drill a 1/2" hole for a generic polarity reversing toggle switch than cut and file a square hole for a GM rocker switch. The toggle pointed to the enabled tank so no bezel was required.
