1991 c1500 compression issues
Discussion in 'Chevy Truck Forum' started by COUNTRYBUMKIN, Dec 4, 2008.
  1. COUNTRYBUMKIN
    COUNTRYBUMKIN New Member
    Dec 4, 2008
    I have 1991 c1500 with a 5.7 engine. all cylinders read 180 psi, but numbers 4 and 6 which read 60 psi any info would be greatly appreciated, by the way it 150,000 miles and has had oil changed religously every 3,000 miles
  2. silverhairdeere
    silverhairdeere Senior Member
    Feb 15, 2008
    1,831
    33
    disabled
    land between the lakes tn
    could be a bad head gasket draining off into the radiator to carbon on valves , to bad rings , does it use much oil or anti-freeze , i probably wrong but it seems about all it could be .
    silver hair deere
  3. COUNTRYBUMKIN
    Dec 4, 2008
    uses less than half a qt of oil between changes and not any coolant
  4. silverhairdeere
    Feb 15, 2008
    1,831
    33
    disabled
    have a garage do a leak down test on the radiator , some more advanced garage have a meter to look for exhaust in the anti-freeze .if that ain't it i'am thinking a valve job , burnt valve , does it have a miss . hopefully one of the bigger brains will chime in .
    silver hair deere
  5. COUNTRYBUMKIN
    Dec 4, 2008
    yes has a rough idle.
  6. silverhairdeere
    Feb 15, 2008
    1,831
    33
    disabled
    i'am thinking the valves and i don't know of any other test other than a tear down . sorry .
    silver hair deere
  7. leolkfrm
    12,925
    8,029
    when you were doing the compression test, did you squirt some oil in the low cyl? if the compression increases it's rings. if there is no change its a head issue, ie burnt valve, bad seat
  8. silverhairdeere
    Feb 15, 2008
    1,831
    33
    disabled
    thank god someone with intelligents came along .:woot:
    silver hair deere
  9. COUNTRYBUMKIN
    Dec 4, 2008
    no i did not do that but will, thank you for info
  10. bradrhale
    be careful as leos head might swell up. that is a good idea and a great way to isolate the problem further. rough idle might be just from poor compression.
