1993 4WD V6 3.0L overheating problems
Discussion in 'Toyota Truck Forum' started by Mike33, Nov 21, 2018.
  1. gmctrucks
    9,678
    5,273
    Check if the lower hose might be collapsing also did you check if the rubber gasket is around the thermostat.
    On my 93 the thermostat goes between the rubber gasket another thing maybe the right head gasket is on the left side of the head or block I’m saying just maybe just trying to help buddy
  2. Mike33
    Mike33 Member
    Nov 21, 2018
    Thank you guys for your input. I ended up working my way down to the water pump and when I took it off it was completely seized up. I’ve got a new pump on and am taking my time replacing the timing belt since I’ve never done one before and I really don’t want to cause myself more problems!
