1994 Chevy 1500 4.3L V6 no start... Help Please!!
Discussion in 'Chevy Truck Forum' started by John Jimenez, Feb 18, 2018.
  1. John Jimenez
    John Jimenez Member
    Feb 18, 2018
    So I have replaced the fuel pump, fuel filter, distributor, cap, and rotor. New battery, ignition coil, map sensor, and fuel pump relay. So the problem is that the engine turns over but it doesn't start. injectors spray and the flame starts up on top of the carb so tells me I do have spark but does not fully start up and run. I did set the timing correctly and all that fun stuff.
    I do have to say, I bought the truck inoperable and hasn't been turned on since 2012. This is how far I got, please help. Thank you
  2. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,120
    2,449
    Fort Wayne, IN
    If it's shooting fire out the top I would guess your distributor is 180 degrees out.
    MikeG, kbrown11 and gmctrucks like this.
  3. gmctrucks
    9,688
    5,276
    I agree with Kenny it sounds like you should start from scratch set number one piston on #1 and so on or maybe the spark plug wires aren’t in the right place look at video below maybe check where your at on the timing.
    Good luck! GMC
    MikeG and kbrown11 like this.
  4. dirtrider73068
    7,114
    4,590
    sales associate
    Easy way to check for timeing is bump over the motor put piston on cylinder 1 at top dead center pull distrib acp and see if the rotor is pointing at the number one cylinder will know if its if off or not if it is need to reset the distrib.
  5. John Jimenez
    John Jimenez Member
    Feb 18, 2018
    Ok so when you say 180 degrees off I turn the oil Pump shaft 180 degrees counter clockwise?
  6. gmctrucks
    9,688
    5,276
    John first check if your timing is off look at the video if the rotor isn’t pointing to the number one cylinder then set the timing like the video shows you it’s super easy view the video several times if it’s ok leave it alone and we can start thinking about what else it might be but doing it this way isn’t going to cost you a dime.
    The video will let you know which way to turn it.
  7. John Jimenez
    John Jimenez Member
    Feb 18, 2018
    Ok ive done that part and same results . I'm thinking to clean the carburetor and giving that a shot ?
  8. John Jimenez
    John Jimenez Member
    Feb 18, 2018
    Can this resolve my problem? Since its like broken?
  9. gmctrucks
    9,688
    5,276
    John you should be able to buy that part at your local auto parts and yes it’s very important that it’s connected correct .
    Another thing get on google and write down what your truck is doing a lot of good stuff will come up and maybe find out what’s up.
    Keep us posted.
  10. John Jimenez
    John Jimenez Member
    Feb 18, 2018
    Ok so I took off the carb with the injectors in it and cleaned it with wire brush . That elbow that was cracked was Soo clogged up, so I cleaned that and got a new elbow. I also put a new gasket since I was there already. But nothing same results o_O I'm so confused on what other direction to go .
    Also , is there other components that I can change that have a 50/50 chance of "fixing" my problem... New ECU???
