77 c10 stock rear gear ratio?
Discussion in 'Chevy Truck Forum' started by brantraynor, Jan 27, 2015.
  1. brantraynor
    brantraynor New Member
    Jan 24, 2015
    Technician
    Lakewood, Washington
    I do not have access to my truck at the moment and was curious what could my stock rear gear ratio be? I have a 1977 chevy c10 with a 350 and 4 speed manual trans. I cant give any description to bolt pattern, etc otherwise I know I can figure it out. Any info would be appreciated. Thank you.
  2. batty1214
    batty1214 Full Member
    Nov 2, 2008
    2,276
    510
    Mine Mechanic(tire guy)
    Vernal Utah
    If I had my guesses, it would be either 3.08 or 3.73. not likely but possible a 4.10. not knowing much about the axle is kinda hard to narrow it down
  3. mowfixer
    mowfixer Full Member
    Jun 20, 2011
    807
    1,491
    Sanford, NC
    This is not exact but will give you a ball park figure:
    If your car has a standard differential then leave one wheel on the ground or both off ground if posi.
    Mark the drive shaft and tire .
    Turn the tire 2 full turns and count the number of times the drive shaft turns.
    If it turns 2 3/4 turns then you have a 2.73. If it turns 3 1/4 turns then you have a 3.23. If it turns almost 3 1/2 turns then you have a 3.42
    This is the way us good ol boys did it in the good old days LOL
    22,489
    13,327
    Axle ratios available in these trucks range from 2.56:1 to 4.47:1 with nine stops in between...be impossible to say.
    Someone may have it optioned to suit their needs..so look at the rear.or look in glove box when you get to the truck for G-codes.
  5. leolkfrm
    12,936
    8,036
    3.73 with 4 speed and f44 chassis option
