Can’t figure out why truck won’t idle
Discussion in 'GMC Truck Forum' started by Austin Tripp, Feb 10, 2019.
  1. Austin Tripp
    Austin Tripp Member
    Feb 10, 2019
    recently bought a 1991 GMC Sierra 2500 with the 350 sbc for 650 bucks, it starts up just fine but only idles for less than a minute and then the engine bogs out and shuts off. Any ideas why this is happening?
    12,925
    8,029
    major vac leak?
  3. Austin Tripp
    Austin Tripp Member
    Feb 10, 2019
    I replaced one vacuum line that goes from the intake to some sort of sensors but Idk where any others would need replacing or where they are
  4. gmctrucks
    9,688
    5,276
    Check fuel pressure or clogged fuel filter and when was the last tune up done. ?
  5. leolkfrm
    12,925
    8,029
    power brake, egr partially open, does it start right back up? ecm temp sensor will cause fits(next to the t stat)
  6. Austin Tripp
    Austin Tripp Member
    Feb 10, 2019
    Couldn’t tell you when the last time it got a tune up, it sat for 2 years and then I purchased it. I will check the fuel system
  7. Austin Tripp
    Austin Tripp Member
    Feb 10, 2019
    I don’t know much about these old chevys, could you explain where I can find thes things?
  8. scavanger
    scavanger Full Member
    May 15, 2007
    1,831
    1,381
    if it runs slower and slower and finally dies I would check the converter.
  9. Austin Tripp
    Austin Tripp Member
    Feb 10, 2019
    If you mean the catalytic converter, it doesn’t have one. Previous owner chopped the exhaust off right before the catalytic converter
  10. dirtrider73068
    7,114
    4,590
    sales associate
    When it shuts off does it start right back up?
