neutral safety switch wiring
Discussion in 'Chevy Truck Forum' started by 918z71, Dec 17, 2012.
  1. 918z71
    918z71 New Member
    Dec 17, 2012
    2001 1500 z71
    Can anyone tell me what color wire goes to what letter position on the 4 wire conector
  2. Boudin
    603
    most gm nuet safety is yellow and purple .....out of ignition switch is a big yellow wire that is crank out and input to nuet saf switch......out of nuet switch is color purple that goes strieght to start selenoid.....purple wire also goes to the crank fuse 5amp.. in the fuse box under dash... this fuse goes to the pcm main computer.. same for auto and clutch
    The park / neutral switch is on top of the transmission. It has a 2 wire connector. the wire colors are pink and orange/black.
    22,489
    13,327
    [TABLE="class: tborder, align: center"]
    [TR]
    [TD="class: alt1"] This is for a 00
    Attached Images [​IMG] [​IMG] [​IMG] [​IMG]
    _________________
    [/TD]
    [/TR]
    [TR]
    [TD="class: alt2"]
    [/TD]
    [TD="class: alt1, align: right"]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="class: thead"][/TD]
    [TD="class: thead, align: right"]
    [/TD]
    [/TR]
    [/TABLE]
  4. Boudin
    603
    You da man, CC. Great post.
  5. 918z71
    918z71 New Member
    Dec 17, 2012
    Perfect!!!!!!!!!!! Thank You CC
  6. Rtsee
    Rtsee New Member
    Jan 5, 2019
  7. Rtsee
    Rtsee New Member
    Jan 5, 2019
    My 2001 silverado has different colored wires than the pnp wiring you are showing. HELP
  8. smokybandit
    smokybandit Full Member
    Jan 26, 2012
    745
    934
    paid fisherman
    texas
    Converting from automatic to manual?
