spongey brake peddle
Discussion in 'Toyota Truck Forum' started by inline50, Aug 24, 2018.
  1. inline50
    inline50 Member
    Oct 12, 2010
    rail road mow
    illinois
    i have a 2008 toyota tundra that the brakes have been acting up. the peddle is real soft and goes down to the floor and will start pulsating with the abs. I changed the master cylinder 130.00 bucks later and its still doing the same thing .
    Anybody have any thoughts on this?
  2. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,123
    2,450
    Fort Wayne, IN
    Did you bleed the master before you installed it? and you may have to have the abs module bled and that may require a scan tool that has abs capabilities.
  3. inline50
    inline50 Member
    Oct 12, 2010
    rail road mow
    illinois
    i did bleed the master cylinder before installation.
    i was having the same issue before i installed the master cylinder thinking that was the problem.
  4. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,123
    2,450
    Fort Wayne, IN
    It may have to be power bled.
  5. leolkfrm
    12,935
    8,036
    did you pull all the wheels and check pads shoes calipers?
  6. inline50
    inline50 Member
    Oct 12, 2010
    rail road mow
    illinois
    k I had a scanner put on my tundra and the code is c1311.
    The way i understand is that i have a bad brake .relay.
  7. inline50
    inline50 Member
    Oct 12, 2010
    rail road mow
    illinois
    can anyone help me on locating the brake booster relay on my 2008 toyota tundra?
    I found two relays that are marked brake1 and brake2 but nothing with brake booster on it.
