Weird check gauges/transmission issue
Discussion in 'Chevy Truck Forum' started by jkeaton, Feb 27, 2019.
  1. jkeaton
    3,230
    5,279
    Speedometer started swinging and then slowly pegged at 100. Tachometer reads 0 no matter what. Check gauges light flickering and trans won’t shift. I can manually shift between 2 & 3, but it won’t shift on its own and won’t go into OD or first gear (manually) just started this on my way home from work. Transmission rebuilt 2 years ago, only put about 4000 miles on it since. Fluid level is good. Replaced the VSS, no change.Going to pull the cluster next to check the ribbon cable connection. Trans was fine before the gauges started acting up. 1995 K1500. 213,000 miles. Thoughts?
  2. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,124
    2,451
    Fort Wayne, IN
    Check your grounds for the cluster.
  3. dirtrider73068
    7,131
    4,598
    sales associate
    I was going to say ground as well, and would check all grounds, that you can find and know about.
  4. leolkfrm
    12,936
    8,036
    scanner time
  5. jkeaton
    3,230
    5,279
    Narrowed it down to the ignition switch. Will be replacing this weekend.
  6. scavanger
    scavanger Full Member
    May 15, 2007
    1,840
    1,385
    do you know you need a very small torx socket to remove the switch .
  7. jkeaton
    3,230
    5,279
    Yes. Thanks. Watched about a dozen you tube videos on it. Does not seem too bad of a job.
  8. scavanger
    May 15, 2007
    1,840
    1,385
    #8 scavanger, Mar 7, 2019
    biggest pain with it is feeding the wire.. no biggest pain is the price .
    Be sure the tie the new harness securely . On my 95 I had the tie had stretched to where tilting
    the wheel put stress on the connections to the switch.I believe that is why mine failed. It was
    an intermittent failure to the fuel pump.
    I found a torx screw that fit like a socket, welded a piece of rod to it and had a super cheap socket.
  9. gmctrucks
    9,700
    5,278
    Way to go JK I’m sure this is going to help more here.
  10. jkeaton
    3,230
    5,279
    Haven't had time to replace i yet. I will report back after I do.
